TO30 Air Cleaner
Brent, IN
03-20-2002 19:50:51
There is a cup in the center of the bowl that you take off the bottom. Do you put oil in the cup or outside the cup in the perimeter of the bowl? Also, what are the best spark plugs to use?
Phil (VA)
03-21-2002 07:29:29
 Re: TO30 Air Cleaner in reply to Brent, IN, 03-20-2002 19:50:51
As to spark plugs, your other question, I use Autolite 3116 and they work very well.
Ken
03-21-2002 04:40:22
Brent-
Oil goes in both inside and out. You can only fill the inside to the level of the holes, then the outside to the line on the cup. Use the same oil you put in your engine.
Ken
drizler
03-22-2002 19:01:52
 Re: Re: TO30 Air Cleaner in reply to Ken, 03-21-2002 04:40:22
I will surely burn for this but here goes. If you can stay away from Champions and go with a Japanese plug.
Brent, IN
03-24-2002 07:52:37
 Re: Re: Re: TO30 Air Cleaner in reply to drizler, 03-22-2002 19:01:52
I heard two other people tell me to stay away from Champion plugs. My tractor supplier sold me Autolite.
r dotts
03-24-2002 08:14:19
 Re: Re: Re: Re: TO30 Air Cleaner in reply to Brent, IN, 03-24-2002 07:52:37
Yes stay away from Champion
I use Autolite 3116 but last time switched to Motorcraft because they were out of the Autolite
RD
