TO 20 STARTER NEEDED
Warren Toms
03-18-2002 07:26:46
I am looking for a replacement starter for my TO 20 Ferguson. It is a 1947 model. The nose of the starter casing is broken. Please contact me at the above e-mail or phone me at 828-245-5156.
Bowser(VA)
03-18-2002 18:04:32
 Re: TO 20 STARTER NEEDED in reply to Warren Toms, 03-18-2002 07:26:46
If your starter is a Delco Remy,replacement parts are available and you should be able to get the needed parts at most any starter and generator rebuild shop.Check your telephone directory Yellow Pages under the automotive listings. Good Luck
Phil (VA)
03-18-2002 14:03:30
I know you assume that because the case is broken that your starter is not repairable easily, but honestly the repair shop I use can do miracles, and I suggest you check with a good repair shop first, if you haven't done so. They may have used or new case parts that will fit, and it will almost certainly be cheaper than buying a starter.
