Hello Dave,Your tractor does sound like a TEA-20, and very like my TEA-20 (1948) in most respects. All 'normal' petrol-only tractors are TEAs. Early TEA tractors did not have the 'thru-the dashboard' air intake, with a grill and a cowl on the dash. Only what the instruction book calls 'later' tractors have that. The instruments and layout sound identical to mine, so its not an MF35, even though it is red. It should be grey all over. Both Continental and Standard engines used a horizontal exhaust, but I'm puzzled by that since I thought only very early tractors had a horizontal exhaust, and my 1948 tractor has a vertical exhaust, and engine number S6860E which is a lot lower than S97847E. Possibly one of them no longer has the original type of exhaust. ( Mine has been converted from petrol-only to run on TVO and petrol, so maybe someone also altered the exhaust.) TEAs were made from 1947 to 1956. They had engines with 80 mm bore and 1879 cc capacity; up to tractor serial number 172501, made early during 1951, when they changed to 85mm bore and 2088 cc.. TEA-20 means a Standard petrol engine. TE's with Continental Z-120 petrol engines were just called TE-20, (or TEB-20 for the Narrow tractor.) You can tell if its a Continental engine because the oil filler is at the front of the engine, not towards the rear. All the UK built tractors are TE-something, the US built ones are TO-something. * Ignition Timing Marks:*
Quoting from a book by Tracprez: - Continental engines (TE20) before tractor serial 36152 have a line on the crankshaft pulley, which lines up with a mark on the timing gear cover, at TDC. If there is no mark on crankshaft pulley, remove the starter motor and find two punch marks on flywheel housing in starter orifice, these will mate with 2 marks on flywheel at TDC. After s/n 36151 there is a flywheel inspection cover on the ignition side of the engine, when cover is removed a TDC mark and single degree line can be lined up against a pointer exposed in the inspection hole; note inlet valve opens, ie tappet clearance is taken up, at TDC. You say it's hard to find the Timing Marks. I'm not surprised !!. * Carburettor Tuning * From my Ferguson factory instruction book. : - The TEA-20s have 4 variants of Zenith carb. If your Zenith has 24 T 2 marked on it clearly, then it's not a Zenith 28G. The 24T2 has 3 kinds of Main Jet adusting screw, (this is the screw near the block, NOT the carb drain, which also has a cross-bar type screw.) and different settings. Here they all are: (For petrol) 24 T2 with cross-bar type of main jet adjuster : main jet 2.5 turns open, 24 T2 with 9/16ths round knob, : main jet 2.5 turns open, (same) 24 T2 with 3/4inch round knob with a peg or hole or rivet head in the face: main jet 1 turn open 28 G: main jet 1.25 turns open. The Slow Running jet has a screw near the top of the carb. The slow running jet for the 24T2 should be 1 turn open, for the 28G its 1 to 1.5 turns open. The settings are almost the same for TVO, and can be varied anyway to suit fuel, climate, workload, etc. Hope this helps. By the way, are you in the US, or Aus, or NZ. ? John.
