Pto shaft
brian
03-10-2002 10:27:10
i'm thinking about replacing the seals around my powertake off shaft on my ferguson 40 this afternoon can someone tell me is this really hard or are they fairly easy. thanks for the help in advance.
Chuck (CA)
03-11-2002 08:01:45
 Re: pto shaft in reply to brian, 03-10-2002 10:27:10
I can't tell you of any easy way to pull out the pto, but you may want to park the front wheels downhill before you do get it out; that will keep the oil from pouring out.
Good luck,
Chuck
brian
03-10-2002 14:22:58
i got all the bolts off from around the shaft and now it won't come out am i for getting something? any help would be great.thanks
tom krizman
03-12-2002 16:54:49
 Re: Re: pto shaft in reply to brian, 03-10-2002 14:22:58
Brian, On the left side of the screen click on Search This Site and search for PTO Shaft. There is alot of info available on what you are experiencing. From what I have read it sounds like your PTO Shaft may be bent. I have an F-40 and I pulled the shaft to replace the seals. Found other small things on the shaft that needed replacement besides the seal but the Massey Dealer did the work for no charge. When I pulled the shaft, what I beleived to be the ground speed gear fell off the shaft. Removed both side inspection plates and got everything back together and it runs well. Never worked on a tractor before. I had the IT manual to help. Big Dean gave some advice, but the gear falling off the shaft is still something that can not be explained. Good luck. If I can be of any help, let me know.
brian
03-14-2002 14:01:25
 Re: Re: Re: pto shaft in reply to tom krizman, 03-12-2002 16:54:49
by chance is there a snap ring or something else that is on the shaft holding it in? i took all the bolts out and it would'nt even budge like it is still bolted there. i have never even used the pto but the seals are very very bad and need to be replaced since the oil is just draining out of it. thanks
tom krizman
03-15-2002 17:37:05
 Re: Re: Re: Re: pto shaft in reply to brian, 03-14-2002 14:01:25
No snap rings holding it in. After the bolts are out it should just slip out unless it is bent.
