Oil Pressure
Todd TX
03-06-2002 19:26:11
At idle speed my TO-35 has oil pressure of about 16lbs and at operating rpm's it has about 23 lbs. Since the tractor has been converted to an alternator I don't know what RPM I am running at but it doesn't sound wrapped out. My question is, is this okay or should I go in an adjust the oil pump? Thanks in advance
Ray,IN
03-07-2002 05:58:33
 Re: Oil Pressure in reply to Todd TX, 03-06-2002 19:26:11
Todd that sounds like excellent pressure, if your gauge is correct. The H. Ferguson tractors pressure relief valve is set at 30psi. I know a former H. Ferguson dealer/mechanic that says if the factory gauge registers any pressure at idle not to be concerned, and anywhere in the normal zone at working rpm is fine.
Dennis in Ma
03-08-2002 17:38:15
 Re: Re: Oil Pressure in reply to Ray,IN, 03-07-2002 05:58:33
I'll second that, Ray.
NCtim
03-08-2002 14:58:20
Interesting reading these oil pressure posts. My tractor registers 60-85psi with an SW gauge that's not factory. I just figured it's wrong.
Mark Hendershot
03-08-2002 17:58:43
 Re: Re: Re: Oil Pressure in reply to NCtim, 03-08-2002 14:58:20
To high of oil presure is not good too. Oil need to go by the bearing at a pre determined speed to pick up heat caused by friction. To low it gets hot to high the bearings arn't allowed to transfer the heat. You may need to adjust the bypass valve in the oil pump. Check your gauge first and see if it is correct. Mark H.
