TO-20 Popping
Jim Nichols
02-28-2002 19:20:30
I have a TO-20 that has had the cylinder head totally rebuilt. I adjusted the valves to the .0015 "cold" setting per the specs and re-attached the valve cover, fuel tank, etc. I then set the timing on the tractor as follows: On the compression stroke of #1 cylinder, I brought the piston to Top Dead Center and set the distributor to the #1 plug wire. It fired right up and runs good at low RPM. However, there is a popping noise from the Oil Bath Air Cleaner at higher RPMs. Did I not get the timing right or is there problems with the carb? I am puzzled.
Chuck (CA)
02-28-2002 21:40:24
 Re: TO-20 Popping in reply to Jim Nichols, 02-28-2002 19:20:30
If I'm not mistaken, the distributor rotates counterclock wise... I once mistakenly ASSumed it went clockwise and of course the wires were wrong. FWIW
Chuck
Jim Nichols
03-01-2002 15:25:29
 Re: Re: TO-20 Popping in reply to Chuck (CA), 02-28-2002 21:40:24
Thanks Ray & Chuck. I do have the wires in a clockwise fashion. I will try your suggestions and post the results.
Thanks Guys!! Runs like a top now!! (JIM)
03-07-2002 19:30:04
 Re: Re: Re: TO-20 Popping in reply to Jim Nichols, 03-01-2002 15:25:29
I took yall's advice. Being an old car nut, I assumed that the dist. turned clockwise. The little tractor runs like a top now. Thanks a bumch!!
Ray,IN
02-28-2002 19:30:17
Recheck the plug wires for proper sequence, sounds like two wires are crossed.
