Removing the Sector Steering Gears, FUN!
Mark Hendershot
02-27-2002 17:09:34
If you ever breake the sector gears it is fun to get them out! You sure have to remove a lot of parts to get to them. You have to pull the steering box off and access them from the bottom, but after you get all the grease or oil out it is just a bolt that slips thru the gear that holds them in. After you remove that bolt the arm sides right out. Mark H.
Boogity OH
03-02-2002 03:59:49
 Re: Removing the Sector Steering Gears, FUN! in reply to Mark Hendershot, 02-27-2002 17:09:34
Hey Mark, if you have your steering box all apart you may want to consider installing three grease fittings to make lubrication of the unit a breeze.
I drilled a 1/8" hole down through the center of one of the control arms to lube the middle bearing and a hole in each side bearing. At the outside ends of these three holes I installed a grease fitting. I had been having trouble with my oil level always getting below the bearing level and I had dry bearings. This cured the problem very nicely. I gave the sector gears a good coating of molly lube at assembly and it seems to work like a charm.
Boogity
Mark Hendershot
03-02-2002 11:15:46
 Re: Re: Removing the Sector Steering Gears, FUN! in reply to Boogity OH, 03-02-2002 03:59:49
That looks like a good idea. I took this one apart to inspect and sell on Ebay. I wish I could have my TO-30 down long enought to take it apart and do the same. I would replace the outside seals on mine if I did they don't look hard to replace after you take it all apart. You have some good photos on your site. Mark H.
