TE20 starter switch
Mike Ferguson-
02-19-2002 15:00:35
Does anyone know where I can get a starter switch fot a TE20? Now I'm starting it with a TO20 switch, but would like to get back to starting it with the gear selecter.
ivan
02-21-2002 07:58:14
 Re: TE20 starter switch in reply to Mike Ferguson- Iowa, 02-19-2002 15:00:35
The switch on my TE did not work when I got the tractor and I tried to get one from a Massey dealer but it was a push button like they use on an 8n. I read on a post here someone took the old switch apart and cleaned it up. I did the same and it has been working great for the last 2 years.
NCtim
02-22-2002 12:36:44
 Re: Re: TE20 starter switch in reply to ivan, 02-21-2002 07:58:14
that's what I did. Haven't had any problems either.
Mike Ferguson- Iowa
02-25-2002 12:13:10
 Re: Re: Re: TE20 starter switch in reply to NCtim, 02-22-2002 12:36:44
I did that too, but it only lasted about a year. The contacts were actually burned too badly.
Mark Hendershot
02-20-2002 17:21:02
The case is the same and so is the shift lever rod with the slot for the linkage to push it when you use the s posision on the shifting lever. Mark H.
Mark Hendershot
02-20-2002 17:12:08
Would a TO-20 switch work if you use the TO-20 linkage that goes to the transmission linkage shift bar opperated by the S on the transmission? Mark Hendershot
Pete@easttn
02-20-2002 15:57:10
Also checked at my local Massey Ferguson dealer and price of switch was over $100.00
NCtim
02-20-2002 13:50:44
Your local Massey Ferguson dealer will have it or get it for you.
