Tight Overhaul
Clay
02-18-2002 12:05:29
I just finished reassembling my TO-20 after getting it back from the machine shop. With the plugs removed no rocker arms installed yet the engine feels tight. It takes an 18" Cheater bar on my adjustable wrench to pull it through. I would guess about 50-75 ft/lbs to move the crank.
How stiff should a new rebuild be? Should I pull it around awhile with another tractor or go back into it? The crank turned by hand, it must be piston rings but the ring gap looked fine.
Rebuilt 6V starter won't budge it. On 12v the starter tries to move it but stalls out.
Chip
02-22-2002 10:02:24
 Re: Tight Overhaul in reply to Clay, 02-18-2002 12:05:29
One of the most important things I learned when rebuilding engines is that you constantly rotate the engine during assembly, install the crank, then the main caps, torque from center out, and after each torque, we would rotate the crank, and continue in that process as we went along, that way, if it suddenly got tight, you most likely could look to the last task you performed. Too many people just assemble everything, and then they wonder why it's tight, but now every task is suspect. Makes for a long day. I found vaseline is a great rebuild lube, it sticks well, yet when engine comes up to temp, it will always melt away, especially when you pack seals with it.
Good luck
Gregg/oh.
02-19-2002 21:30:16
Even though the 6 volt starter should turn you over, the rope rear main seal on these engines can really make a engine crank hard, worse when put in dry. I put together the whole engine then install the rear main (lower) last. to get idea how the engine turns over. If the rear main rope seal was left a little long,after cutting to size, I have these engines flat locked up.after the rear main cap torqued down. hope this helps.
twopop
02-18-2002 18:50:47
you say the crank turned by hand,whoch it should have,but i cant turn a crank by hand when the rods are on.so i would check the rod caps,see if one is on backwards.or take one loose and turn engine.check one at a time,until you find the tight one,or so.i would bet on the rod caps.dont pull it around or you could score the crank.you may need to plastigage the rods.
Ray,IN
02-18-2002 19:07:29
 Re: Re: Tight Overhaul in reply to twopop, 02-18-2002 18:50:47
I agree, you say your ring gap is correct so that rules out incorrect piston to cylinder measurment. That only leaves the rod bearings. Did you use a mixture of STP and motor oil when assembling everything or similar mixture? The initial lubrication is critical, and pulling it will not build oil pressure quickly enough to prevent bearing damage or breaking a ring(s). Follow twopops advice and eliminate each rod,recheck bearing alignment and recheck tolorances. A little extra time now will guarantee engine longivity.
