Manual TO-20 Harry Fergusion
Gene Willoughby
02-16-2002 21:31:34
Someone told me about a manual for the TO-20 H Fergusion tractor for $14 but I misplaced the information, could you please resend it to me!!!
Thanks Gene
P.S. Igot tractor cranked but it want stay running over 2 minutes at a time. Rebuilt carb. but still same problem. Any helpful information.
P.S.S. would like to now about converting over to 12 volt system.
Gene
Phil (VA)
02-21-2002 12:52:30
 Re: manual TO-20 Harry Fergusion in reply to Gene Willoughby, 02-16-2002 21:31:34
As to why it won't stay running, give us more info. Do you suspect spark or fuel? Check for both. Does it restart right away after it shuts off? Or do you have to let it cool down? That could be a key piece of info. If the latter is the situation, often it is a bad coil. There really is no easy shade tree way to check the coil. Most people who suspect it, just replace it and see if that fixes the problem. If it does, great; if it doesn't, well now they have a spare coil. Otherwise, if you think it is fuel related, remove the gas line from the carb and check the fuel flow to the carb. It should flow strong and steady, like a man urinating. Perhaps the fuel line is semi-clogged, and after it sits a few minutes enough fuel drips to the carb for it to start and run until it runs the fuel out of the carb.
Dennis in Ma
02-17-2002 13:15:01
click on tractor manuals at the left of this page
Chuck (CA)
02-16-2002 22:06:20
Hi Gene,
Don't know about $14.00, but maybe.
Click on the link below and place your bid. It's now at $2.00
Good Luck,
Chuck
