Talk about a Hard Job try this some day!
Mark Hendershot
02-15-2002 16:55:56
On a TO-20 I pulled the Complete Front End off, Pulled the Engine, Split the Tractor in 3-Sections, Completely removed all the parts and gears from the transmission housing, Pulled the Pinion Gear, Removed the Left Trumpit and Rear tire, Pulled the Rear Differential, and the Complete Steering Assembly too! I was amased after fifty years of use there was NO WEAR or CHIPS on any Gear they looked like new! Took about 5-6 hours to do. So inspecting the pump isn't so bad. I hope you don't have to do this!! Mark H.
d rizler
02-22-2002 12:18:06
 Re: Talk about a Hard Job try this some day! in reply to Mark Hendershot, 02-15-2002 16:55:56
Mark I hope you didn't do all that just to pull the pump. Say it isn't so; it drops out the bottom real nicely.
Mark Hendershot
03-05-2002 12:48:15
 Re: Re: Talk about a Hard Job try this some day! in reply to d rizler, 02-22-2002 12:18:06
No I did that to part out the Tractor. That would have been a real bummer if it was to get the pump out. Mark H.
