Overdrive on a TO-30?
Randy
02-13-2002 10:13:30
I have a 1953 TO-30 with a lever on the right side of the transmission, just behind the engine block. The guy that I bought it from said it was the overdrive lever. When I drove it with the lever engaged, ground speed was greater in all four gears than in the disingaged position. I have never heard of a TO-30 with overdrive before this. Does anyone have any information?
Mark Hendershot
02-13-2002 18:15:28
 Re: overdrive on a TO-30? in reply to Randy, 02-13-2002 10:13:30
You may have the 2-speed or the 3-seed combination one. If when you are in the middle of the shift on it and can pull the lever out and shift it again you have the 3-speed one. I have the 3-speed on mine and it gives you 12-forward gears and 3-reverse gears. Mark H.
Randy
02-14-2002 04:23:59
 Re: Re: overdrive on a TO-30? in reply to Mark Hendershot, 02-13-2002 18:15:28
Thanks for the info Mark. I'll check it out.
Duner Wi
02-13-2002 13:30:08
This site will give you some info.
Link
Do a search for "step up" on Ferguson and N Ford board for possoble additional info.
