Wagner loader
Jeff S.
02-12-2002 19:31:20
I have a '53 TO30 with a Wagner front loader (Model: FORD W3M) on it. The bucket cylinder seems to be too long on it and appears to have been replaced at some time. The bucket does not tip back enough to hold material well. Does anyone out there have any information on the length of the cylinder?
Jeff S.
02-13-2002 20:22:27
 Re: Wagner loader in reply to Jeff S., 02-12-2002 19:31:20
Wow! Thanks guys, looks like I have some new ideas now.
Jeff S.
Dennis
02-13-2002 11:42:38
I have a wagner on my to-30 and it never tipped back more than level more or less. I blew out the ram and recently bought a new one from northern hydraulics. It is a 16inch cylinder and is exactly the same as the old one in size - and tip. At one time I welded a bracket on the top of the frame cross bar that holds the upper end of the ram. That moved the ram back further and pulled the bucket back too. The bracket broke and has yet to be replaced, but I figured moving the ram mounting once was better than altering the two - make that three- buckets I have. Couldn't figgure how to move it on the bucket anyway as if you move the mount higher, you need a shorter ram to tip back and if you move it down the bucket, you lose the optimum levering angle which is none too good now.
Roger
02-13-2002 12:11:59
 Re: Re: Wagner loader in reply to Dennis, 02-13-2002 11:42:38
...Come to think of it, I had also moved the
mounting bracket on the frame to get more
tilt-back on the bucket...
Roger
Roger
02-13-2002 09:45:42
Jeff;
I had a similar problem with the loader on my
TO-35 and I moved the cylinder mount on the
bucket. Or you can get a cylinder with a stroke
matching the current spacing.
Hope this helps.
Roger
