Loader wont lift
Green Horn in T
01-17-2001 19:15:43
I recently bought a IH 1566 w/ loader. While feeding hay I had a hose break. I've replaced the damaged section of hydrolic hose but now the loader doesnt lift as high as it did before. I've tried adding hydrolic fluid, but notice no change, any suggestions?
-perplexed green horn in TX
ltf in nc
01-17-2001 19:47:47
 Re: loader wont lift in reply to Green Horn in TX, 01-17-2001 19:15:43
Green Horn,
Usually raising and lowering the loader, without any load, will force any trapped air from the system. I am sure tht you have done this but maybe you need to do it a couple of dozen times and always hold the control lever to the maximum at the end of each stroke to the point that you hear the relief valve start to squeal. Good luck
