IH 2424 two stage clutch problem
ange
01-13-2001 15:58:32
I have a 2424 with 2 stage clutch that will not engage with an impliment on. Someone told me that if they are not used for along time that it will rust together. Is this possible and can I break it loose wout splitting the tractor? Any ideas or options would be great.Thanks Ange
AZjbird
01-14-2001 06:59:31
 Re: IH 2424 two stage clutch problem in reply to ange, 01-13-2001 15:58:32
Hi ange, Nice to see someone else has one of these lil` jewels! But think about it, if the 2 stage was rusted together, it would be engaged all the time right? I hate to say it but I think you`r going to have to inspect it. Maybe it got wet and is slipping. Oil infiltration, condensation? Ange, I`d like to hear more about your machine if you get the chance. My `65 is all orig and works fine, but it`s the only one I`ve ever seen! good luck J.
ange
01-14-2001 18:57:13
 Re: Re: IH 2424 two stage clutch problem in reply to AZjbird, 01-14-2001 06:59:31
Hey AZjbird my 2424 came from a cemetery where it was used for pulling and the pto was never used. I was told that lack of use could cause it to rust and lock up. Ive tried to b reak it loose with a bushhog to no avail. it will engage with a posthole digger but not a mower. If I am correct the 2 stage means that pushing the clutch in half way should allow the tractor to stop and the pto will not. This one will stop the tractor but not the pto when clutch is pushed all the way in. I dont know the year but its yellow and runs good. thanks for the reply. ange
