IH 966
Gilbert h.
12-06-2000 06:22:09
Tractor pulls great on flat ground but will completely stop on grade. I can let it roll back down the grade, and in about 1 minute it will pull again but will quit once on grade again. I think it has to be a hydrolic problem but don't know where to start looking.
Gilbert h
12-15-2000 12:55:54
 Re: IH 966 in reply to Gilbert h., 12-06-2000 06:22:09
Tried your suggestions. In low/2 (1/2 throttle) strained hard and brakes wouldn't hold under all the preasure I could put on them. In high/2 it strained at first then tried to die. This brings me back to my first thought; a hydrolic problem. Where could it be?
ltf in nc
12-06-2000 09:03:49
Sounds as if the hydraulics are starving for fluid. Have you verified that the levels are good and that the filters are clean? My old Cat 955 will do the same if the fluids get low.
Mudcat49
12-06-2000 06:30:13
On flat ground put it in high 1 or 2, TA if it's got one in high, lock brakes together throttle about 1/2, hold brakes and let out clutch, iffen it doesm't die or strain then you have a bad clutch.
JohnIH
12-06-2000 13:03:48
 Re: Re: IH 966 in reply to Mudcat49, 12-06-2000 06:30:13
I agree with Mudcat49's assessment. It sounds like a classic TA or clutch problem. If it only does it in low range it is a bad TA, and if it is in both ranges it is probably the clutch.
JohnIH
Gilbert h
12-14-2000 07:53:54
 Re: Re: Re: IH 966 in reply to JohnIH, 12-06-2000 13:03:48
Thanks for the information. I'll try it and see what happens. Please excuse my ignorance but TA means?
