Today's tire sizes for 1950 H
Grant
10-06-2000 13:04:32
What size tire, in today's size specs, would be correct for a 1950 H? I'm ready to buy, and I'm being told a lot of different things!
Jim Becker
10-09-2000 09:11:06
 Re: Today's tire sizes for 1950 H in reply to Grant, 10-06-2000 13:04:32
They came with different sizes. How wide is your rim? Read the sidewall of a new tire. It will say something like "12.4-38 on an 11" rim." That is OK on a 10" rim but don't go more than 1" over the sidewall label for an original look.
Mike
10-07-2000 03:22:37
My cost on an 11.2 38 4ply field & road is aproximately 175$ the tube is aproximately 15$ and the mounting, if the tires are dry and rims are good, would be 1 hour of service or 35$; or 415$ for a new pair mounted
H MN
10-06-2000 19:34:29
Grant: Guy Fays book stated 10x38 standard for the '39 to '52 H. I kinda think the 11.2 took that place. Red's the expert on H's but back in the 40's and early 50's most didn't put too large a tire on as they do now.( if your trying to match the 1950 look) harvey
Doug D
10-06-2000 18:38:13
I just put a set on the rear of my 1940 H this summer. I was told that 11.2-38 was the best match for the original 12-38. They look great. I would have to run out (and it's darn cold right now so I am not) and check the name, but they are Goodyears and I bought them at Superior Coach Sales in Perrysville Ind. New tires, tubes and mounting was just a couple bucks over $400. By far the cheapest place I have ever found Goodyears at. Incredibly nice people as well. Phone number is 1-800-231-8895. Dick Crist is in charge and they are in West Central Indiana, Just off exit 4 on I-74.
Doug D.....well I might be wrong
10-06-2000 18:42:28
 Re: Re: Today's tire sizes for 1950 H in reply to Doug D, 10-06-2000 18:38:13
They might be 11.4-38 instead of 11.2-38. I won't swear to it, but either way it is one of the two and they only make one size or the other. They sure do look "correct" though. I am very pleased. Hope this helps.
Have a nice day, Doug.
The Red
10-06-2000 13:52:34
Grant 12.4 x 38 for the rears and 5.50 x 16 for the fronts. Don't forget new intertubes!!
Andy Martin
10-06-2000 18:29:14
 Re: Re: Today's tire sizes for 1950 H in reply to The Red, 10-06-2000 13:52:34
And before you put the tires on the rims, wire brush the rim, smooth rough spots, and paint it (on the side where the tube touches the rim). I use a zinc chromate primer. Let the paint dry for a good two weeks.
Then use lots of talcum powder on the tube.
I know that is a long time but you'll thank yourself the next time the tire comes off. And it may be longer before it comes off.
Ditto, What Red Said.
10-06-2000 16:10:06
sammy the RED
