Was the Diesel in the TD-6 crawler used in any wheel tractors.
Anton
06-26-2000 10:56:34
My question is for interest, and because I am looking for rebuild parts for the hydraulic pump between the timing cover and distributor on an early 1950s TD-6 diesel(4cyl). I've seen pumps listed for IH wheel tractors in catalogs but not the TD-6.
Thanks.
Redfan
06-26-2000 13:32:46
 Re: Was the Diesel in the TD-6 crawler used in any wheel tractors. in reply to Anton, 06-26-2000 10:56:34
Same motor was used in WD6 and Farmall MD tractors. I can't guarantee hydraulic pump was the same for all, but I would imagine it was. Regards, Redfan.
Jon
06-26-2000 17:18:42
 Re: Re: Was the Diesel in the TD-6 crawler used in any wheel tractors. in reply to Redfan, 06-26-2000 13:32:46
if i'm not mistaken, the same pump was used in the 400 and 450 tractors, right? someone please correct me if i'm wrong.
Regularman
06-27-2000 09:28:23
 Re: Re: Re: Was the Diesel in the TD-6 crawler used in any wheel tractors. in reply to Jon, 06-26-2000 17:18:42
Yep, I would agree the TD-6 and 400-D and 450-Ds were the same motor and probably the same pump (appears the same from the outside, anyhow).
