International 3488
Billy
12-29-1998 09:52:43
I have a 3488 with 8600hrs. I have chance to buy a 5288. Can one give me info. on this tracter.
Todd Markle
12-30-1998 18:30:32
 Re: International 3488 in reply to Billy , 12-29-1998 09:52:43
I cant tell you a whole lot, but I remember when these tractors were new because my family had an IH dealership at the time. I was only about 12 at the time. The 5088 has an 18 speed trans. 6 gears
and 3 ranges. I believe your 3488 has 8 speeds and
2 ranges. The shifts from 1-2,3-4,5-6 are power shift (basiclly the same as the T/A on older tractors) The 50 series had a much heavier rearend
and transmission than the 30 series. A friend of mine traded a 1466 on a 5088 a few years ago and he really likes it.
Scott Klitzke
02-17-2004 19:21:18
 Re: Re: International 3488 in reply to Todd Markle, 12-30-1998 18:30:32
The 3488 was a hydro...not a gear drive tractor. The 3688 was the gear drive version. The 30 series (3088, 3288, and 3688) had basically the same transmission as the former 66 and 86 series tractors. The only difference is that the TA lever was eliminated and instead the TA was electrically actuated by moving the gear shift lever from side to side. The 50 series (5088, 5288, and 5488) were an all new transmission with 18 speeds. There were three ranges with six gears in each range. You were able to powershift from 1 to 2, 3 to 4, and 5 to 6.
George
12-29-1998 15:17:02
Neighbor has one he likes it. Uses it for his heavy work Like breaking alfalfa pulls 6x16
John Deere Jim
12-29-1998 13:13:10
The best thing you could do BILLY BOY is run that old binder down over a hill somewhere and your troubles will be over. As far as the other old binder do your self a favour and look at good tracter like a JOHN DEERE.
Mark R.
12-30-1998 20:22:32
 Re: Re: International 3488 in reply to John Deere Jim, 12-29-1998 13:13:10
You need to get a life and a REAL! tractor.
Eric D
12-30-1998 21:06:32
 Re: Re: Re: International 3488 in reply to Mark R., 12-30-1998 20:22:32
we have a 5088 and i love it. The only thing, drive it until it get's good and warm and see if it has a growl in the hydraulic system,(IT ONLY DOES IT WHEN IT'S GOOD AND WARM)!!! this noise will drive you crazy. this problem is fixable.
Robert Campbell
12-30-1998 05:44:26
JUNK DEERE JIM,
Hopefully when he runs it over the hill, it will run over a couple of those worthless JD tractors that didn't have power enough to get up the hill. (that wouldn't take much of a hill)
Besides, if you are such a JD fan, why are you looking at the IH Farmall discussion group?? Maybe you are about to wake (or grow) up!!!!! !!
John Deere Jim
12-30-1998 21:17:58
 Re: Re: Re: International 3488 in reply to Robert Campbell, 12-30-1998 05:44:26
Take her easy old Bobby fellow you could blow a casket there. I,am having a bit a fun, after all it is the holidays. CHEER!!
