H hydraulics
Gip
03-27-2000 12:16:39
Does it matter which port on my 48 H I hook up a Hydraulic line too. I'm using it to pick up my belly mower.
The Red
03-27-2000 12:57:09
 Re: H hydraulics in reply to Gip, 03-27-2000 12:16:39
No Gip it doesn't All 3 pipes come out of the same manifold. The rear one on the battery side has a slight delay on the pressure but you will not notice on the mower.
gip
03-27-2000 13:05:41
 Re: Re: H hydraulics in reply to The Red, 03-27-2000 12:57:09
Thanks Red I added this page to my favorites list. Its great to have such knowledge available.
Keith
03-27-2000 13:38:08
 Re: Re: Re: H hydraulics in reply to gip, 03-27-2000 13:05:41
If you connect to the rear port on the left side you will have to force the control lever through the first stops which control the front ports, and then release the rear port by pushing the lever all the way down. This port is for the delayed lift cultivators. My advice is to use either of the front ports. Keith
