farmall h governer
donald schnuppe
05-21-2008 18:41:27
Do the springs on the throtle rod under the hooh have anything to do with the governer working right.The tractor will pull way down im rpms before it kicks in and speeds up? thaks Don
RustyFarmall
05-22-2008 04:26:05
 Re: farmall h governer in reply to donald schnupper, 05-21-2008 18:41:27
No. The sluggish response is all inside the governor.
bgarrett
05-22-2008 04:35:23
 Re: farmall h governor in reply to RustyFarmall, 05-22-2008 04:26:05
what goes wrong with a governor?
all my parts move freely
usetabesteve
05-22-2008 05:16:06
 Metal to metal contact. in reply to bgarrett, 05-22-2008 04:35:23
Even with lubricant, the parts will wear. When there is enough wear to make some slack in the mechanism, you get that draggy feeling. Springs lose their tension as well, and sometimes break. You have to take it out, look it over, replace the spring, and replace the worn bits.
