H Super H transmission gear teeth
MM ZAck
05-06-2008 16:40:21
Does anybody know the tooth count for the gears in Super H transmissions? I'm looking for the sliding gear counts, the ring & pinion and the bull gears. Also, where are the differences between the Super H and H transmissions? Is it in the sliding gears, ring & pinion or bull gears? I believe they both use the same 18-55 constant mesh. I'm curious because I'm calculating the over all reductions for each gear on both tractors.
Thanks,
Zack
r4etired
05-06-2008 19:30:27
 Re: H Super H transmission gear teeth in reply to MM ZAck, 05-06-2008 16:40:21
The constant mesh gears will interchange but the SH is about 1/8in wider.
Andrew Z
05-06-2008 18:43:53
The gears them self are wider on the Super H. Im not sure that this effects them being swaped from one to the other or not?
Andrew
CNKS
05-06-2008 17:12:29
Gear counts are in the parts section in www.caseih.com.
MM ZAck
05-07-2008 07:38:15
 Re: H Super H transmission gear teeth in reply to CNKS, 05-06-2008 17:12:29
Awesome. That's exactly what I was looking for! Thanks!
