400 general
littlemackinawfarmall
04-27-2008 16:56:17
Hey thanks Jan seems to be it seems to giggle a bit more than my M's just sitting there at idle and full throttle....guessing flywheel? Or could it just be needs a good workout? Doesnt seem to have the RPM's that my super m has or maybe its in need of a good tune up and hooked to an auger...Anyone know where to buy a tach and housing has the knockout cover on the hole but since the guy bought FastHitch he said he left out 12volt powersteering and tach.
Janicholson
04-28-2008 06:03:47
 Re: 400 general in reply to littlemackinawfarmall, 04-27-2008 16:56:17
Put a shaft tach on the PTO, or a strobe tach on the pulley to see what RPM it is set at for High IDLE, and load if possible.
YOu can pull the starter and use a dial indicator on the FW to check runout.
Also pulling plug wires one at a time can isolate mis issues. Let us know. JimN
