300 Utility
Ap300
04-25-2008 22:34:19
Just got a 300 Utility and it looks like I have a problem....and a few questions. When I start the tractor a watery substance starts to drip/pour out from underneth the tractor. It is coming out from the bottom of the tractor directly below the main shifter. There is a large hole about 2 inches square broken in the bottom of one of the covers. The hole is right next to the PTO disconnect lever. Is there normally fluid in this compartment? Anyone know where I could get a new cover plate? What do you think the problem may be?
Thanks for the help....I am a newby to the 300 series.
Janicholson
04-26-2008 05:47:03
 Re: 300 Utility in reply to Ap300, 04-25-2008 22:34:19
It could be condensate in the gearbox, drain and see if h2o comes out first. There may be a need for a new seal, (usually a split of tractor to access) JimN
