governor
Tracy H
04-20-2008 15:18:56
Can someone tell me how to adjust the governor on a 140?The motor needs to run a little faster under a load.I have checked that the length of the governor to carburetor Control rod is set right. Thanks Tracy
teddy52food
04-20-2008 18:26:54
 Re: governor in reply to Tracy H, 04-20-2008 15:18:56
Did you put a new spring in it? Remember the spring opens the throttle, the flyweights close it.
Doug C.
04-20-2008 16:03:28
Hi Tracy,
I'm still putting mine back together, so I haven't got to the adjustment part yet. There should be plenty of info about governor adjustments if you search the archives.
Good luck.
