Hydralic oil on H
Booth2563
04-15-2008 17:53:36
I got my new radiator on my H and started it up and now oil is pouring out of the belly. can someone tell me where this is comming from and tell me what I need to look for and tell how hard it will be to fix.
Thanks David
Bill Lisbon
04-15-2008 19:07:16
 Re: Hydralic oil on H in reply to Booth2563, 04-15-2008 17:53:36
What kind of oil is leaking, if it's engine oil, the rear engine seal is leaking, if it's gear oil the front transmission seal is leaking. If it's hydraulic oil the hydraulic pump is leaking.The hydraulic pump is removed by taking all the pipes and fittings off, Remove control handle. Take down small plate and remove coupling. Slip a piece of pipe through the bottom of hyd. assy. have someone help hold it up until you remove bolts, then drop pump. you can check all your seals with pump out of the way.
