Independent PTO
Nifty 350
04-15-2008 09:21:04
I recently took out the drain plug on an old IPTO unit that had been laying in the field for a long time. Instead of oil coming out, water did. The unit has no holes and the shaft and seal are OK. I was wondering how water could fill up in the case.
Janicholson
04-15-2008 09:44:26
 Re: Independent PTO in reply to Nifty 350, 04-15-2008 09:21:04
Other than a flood, the most likely is condensation. As the temp varies, the breathing in and out collects moisture and it can even lift the oil out of the breather, and replace it with water. JimN
