roosa master fuel pump removal
Giesbros
03-30-2008 10:48:02
Anyone know give advice on removing 806 injector pump(roosa master) the pump shaft came out of the pump and is still in the block. We have pulled them out of our jd4020s these seem to be different. Any help would be appreciated.
Owen Aaland
03-31-2008 08:03:45
 Re: roosa master fuel pump removal in reply to Giesbros, 03-30-2008 10:48:02
The 806 does not use the lip seals on the shaft like the D236 and D282 have. The seals are in the pump adapter which is why the pump drive shaft stayed on the engine. If you look at the end of that shaft you see a dimple on one side of the flat part. There is a matching dimple in the pump. Match the two together and the engine will be in time.
If you did not wire the throttle back, stand the pump on end and look inside to make sure the governor fork is engaged with the two slots on the governor sleeve. If they are not in place, just line them up and then wire the throttle lever back.
ejr-IA
03-30-2008 12:43:53
Hope you indexed the pump timeing marks before you pulled it otherwise you have to go through the timeing process.Yes the shaft stays and don't forget to install two new pump seals and oring.Also wire the throttle control linkage back like as in full speed advance.When going back together becarefull not to roll back the new pump shaft seals.
Curt W.
03-30-2008 19:08:17
 Re: roosa master fuel pump removal in reply to ejr-IA, 03-30-2008 12:43:53
Make sure you have the proper tool to put those seals in. They're way to easy to flip or tear. I've done it and the fuel runs into your motor oil.
