Update on Landfill 350
Greasy John
03-28-2008 14:12:02
Thanks to Rootsy I now have the new axle bearings in her. Took off the PTO- thought that was heavy "I am on the hi side of 77" but found out the axle and housing are REALLY heavy to carry 10 ft to the bench.Now -where do I look for a reasonable hyd valve to add to the two I have on the 350. There is a spacer abt 1/2" thick next to the dash but it just barely goes thru the bracket so think I will need the proper lever and linkage also + the outlet lines. The valves will have to have the longer 2 studs and 2 bolts also I think.The fast hitch is on the outer most lever is this proper?Boy there is a big difference in bearing prices--all the way from 78 to 148 dollars for the same bearing. The loader works the way it is but have to use a quick disconnect behind the set -- kills my fast hitch . Any info appr. Tnx .
