I-9 Front motor mount removal
Dave I-9
03-25-2008 20:04:53
I recently acquired a 1948 I-9 with a stuck motor and the remains of a U-9 power unit with a good motor. I am trying to put the U-9 motor in the I-9 , I have the bellhousing flywheel and clutch swapped over but my problem lies in the front motor mount which is different between the tractor and the power unit. My question is if the mount is part of the front cover or if it can be swapped without changing the front cover. I appears that the mount is supposed to swivel on the front cover but i am not sure if it just pulls off the cover or not, i already have the crank pulley removed at this time.
Thanks any help is appreciated, i am hoping to have the engine installed tomorow night.
Thanks
Dave Meixner
Chuck46
03-26-2008 08:36:24
 Re: I-9 Front motor mount removal in reply to Dave I-9, 03-25-2008 20:04:53
Dave, Yes they should come right off, if it wasn't greased it might be rusted on. Good luck, Chuck
Dave I-9
03-26-2008 18:18:08
 Re: I-9 Front motor mount removal in reply to Chuck46, 03-26-2008 08:36:24
Thanks with a little help from a pair of hammers i got it off.
Thanks again
Dave M
