1066 Wiring question
JasonIH
03-24-2008 21:38:14
Been looking for a fuse box of some sort but all I've really found is a single fuse in the dash. I just can't see that being the only thing that runs the blowers and lights.
Is there a place online that sells cab aftermarket interior parts.....like weather stripping....floor mats...cowel covers..? Thanks!!
Allan In NE
03-25-2008 05:36:15
 Re: 1066 Wiring question in reply to JasonIH, 03-24-2008 21:38:14
Originally, the 1066 with a cab used two fuses; the standard one in the dash for the lights and then also another one up under the outside roof panel of the cab for the radio.
Everything else is powered off of two circuit breakers and a relay located inboard of the right-side battery.
Four-way flasher and neutral/saftey switch is located under the left floorboard and the turn signal flasher is located over on the other side also inboard of that right battery.
Do a search of "Harold Electric" for your cab interior rebuild, as they have it all.
Allan
