IH 1486 Hydraulics
Redpowerman
03-11-2008 17:31:14
I have a 1486 with a hydraulic problem hopefully you guys can shed some light on the situation. When I pickup my 12ft discbine, the discbine settles down rather quickly. It seems that the hydraulic pressure wont keep it raised up. The 3pt hitch works good and will keep a load raised up. I was wondering if the orings in the spoolvalves are leaking by. ANY HELP WILL BE APPRECIATED. THANK-YOU!
billonthefarm
03-12-2008 05:20:47
 Re: IH 1486 Hydraulics in reply to Redpowerman, 03-11-2008 17:31:14
Allan is right, check the cylinder. Then make sure the tips on the hoses are ok. I had this on my 1086 and when it was on the baler the twine arm would creep. I ended up rebuilding the cylinder on the baler and the spool valves under the floor of the cab and that took care of it. bill
Redpowerman
03-11-2008 18:02:00
Yes both remotes settle. The system has good pressure it will raise the implement fast,but won't hold it there wounce it is raised up.
Allan In NE
03-11-2008 18:19:15
 Re: IH 1486 Hydraulics in reply to Redpowerman, 03-11-2008 18:02:00
Try a different cylinder. Odds of both remotes going bad at the same time are kinda slim.
Allan
Allan In NE
03-11-2008 17:44:59
Both remotes settle?
Allan
