super c fast hitch trouble
beer
12-18-2007 14:57:32
I have a super c fast hitch, goes up fast and does not labor motor.On the down cycle it goes real slow and boggs down the motor. thanks for any help
georgeky
12-18-2007 23:26:53
 Re: super c fast hitch trouble in reply to beer, 12-18-2007 14:57:32
After thinking about it there is two possibilities Mine with the hi way mower valve was for a mid mount mower and not fast hitch. The fast hitch with the valve for it will likely just have a retarding valve that Gene mentioned in the elbow where the hose hooks to the cylinder. You can just take it out and install one without the valve. That will make it work the same speed up and down. For my valve, I have to change the spool in it. Yours should be a cheap fix.
gene bender
12-18-2007 19:53:39
its supposed to go down slow there is a retarder in the line to make it go down slow
georgeky
12-18-2007 18:26:03
Nothing wrong with it. It has a hi way mower valve in it to retard lowering. I have 2 with fast hitch. One does the same as yours and the other does not. Check with your IH dealer and for a good price he can sell you the other valve.
