706 Farmall
Goose
12-07-2007 20:36:49
I was just talking to a buddy of mine. He has a line on a 706 diesel, says it doesn't look too bad, but if you put antifreeze in the radiator it goes straight to the crankcase. The owner wants $500 for it.
As I recall, there were two different diesel engines in the 706's, one German and one IH. Are they both dry sleeve? Any ideas, outside of a busted block? I told my buddy if he decides to pass, I might be interested, which may or may not be too smart.
Goose
12-08-2007 13:57:27
 Re: 706 Farmall in reply to Goose, 12-07-2007 20:36:49
Thanks for the response. Without going into it any farther, I'd venture a guess it's a German diesel with a sleeve seal leaking. I knew the IH engine would be dry sleeve, but wasn't sure about the German. I'll see what happens.
MN Scott
12-07-2007 20:53:17
German wet sleeve, American dry sleeve. If its the german the sleeve orings like to leak. Could also be head gasket, cracked head/block or numerous other things causing the leak in either engine. $500 is less than scrap price so you could part it and make a good bit.
