LP to Gas conversion on 1954 Super C
Joe Kimbriel
11-30-2007 08:02:16
I pulled off all the LP stuff and replaced fuel system with gas carburetor. Tractor runs, but the choke needs to be about half on. I found two drilled holes in the intake manifold witch I plugged but still needs choke. Are there more holes that I cannot see?
Thanks, Joe
CNKS
11-30-2007 09:47:39
 Re: LP to Gas conversion on 1954 Super C in reply to Joe Kimbriel, 11-30-2007 08:02:16
It's too lean, clean the carb, put a kit in it and set the float to specs.
Joe Kimbriel
11-30-2007 17:34:43
 Re: LP to Gas conversion on 1954 Super C in reply to CNKS, 11-30-2007 09:47:39
I did the kit, but must have screwed it up some how. I"ll try again.
Thanks,
Joe
CNKS
11-30-2007 17:43:00
 Re: LP to Gas conversion on 1954 Super C in reply to Joe Kimbriel, 11-30-2007 17:34:43
By cleaning, I mean carb cleaner, soak it at least overnight, blow out with compressed air. Make sure all openings are clear.
