300U hydraulic Surging
Matthew William
11-13-2007 11:31:39
I just added, finally, the PTO and two point hitch. I also fixed several hydraulic leaks. I noticed yesterday that as the tractor sits idling that there is a surge of hydraulic pressure. It is kinda nice as when it surges it provides enough power to turn the front wheels.
Is this normal or did I mess something up?
I haven"t driven it since I fixed the all of the above as I am now changing it to 12v.
Thanks for your input. I read a bunch of the steering posts that came up when I searched but none of them talked about this issue.
Janicholson
11-13-2007 13:32:24
 Re: 300U hydraulic Surging in reply to Matthew Williams, 11-13-2007 11:31:39
It has a good possibility of being a sticking powersteering diverter (term might not be that used in the manual) valve. in the supply to the PS unit JimN
Matthew Williams
11-14-2007 08:38:03
 Re: 300U hydraulic Surging in reply to Janicholson, 11-13-2007 13:32:24
Is that a problem and if so how do I go about diagnosing and fixing.
Thanks!
