American Bosch PSB pump
msb
11-10-2007 18:48:23
Posted this over at Case- no response. Doesn't some IH tractors use the same pump? Someone mentioned the possibility of a broken pin in the pump? TIA,bob
Long story /short version. Primary filter plugged, finally just removed it. Replaced the next two filters-both full of crud.Also finally got system primed-gravity. Pulled the transfer pump--O.K..Still no start. Pulled the governor cover. Linkage was stuck, freed it up. Still no start. Took the side cover off. Nothing turned when engine was cranked. I assume the gear I see turns the distributor? Sale in in morning. I assume something inside the pump is broken? I hate to get beat.Trouble at every turn.I shall overcome. lol. Any help is appreciated. E-mail is open.Thanks, bob
