584 front axel
ken Opiat
11-07-2007 19:58:28
hello and thanks to all those that helped with range trans shift lever..... .I did like the mechanic from Quebec said and everything turned out just fine..... .and then...believe it or not, the nest day I broke the front end...it's called the bolster or main front support..... .I've got everything off ...this thing is what the radiator sits on, and bolts to the engine block...how do you sepparate it from the front axel???? any help out there would be much appreciated..... .thanks again...ken
ken Opiat
11-08-2007 17:12:45
 Re: 584 front axel in reply to ken Opiat, 11-07-2007 19:58:28
hello .the pin comes out by using a 5/8 coarse thread bolt attached to a slide hammer...or make your own tool to pull it.it comes out pretty easy.ken
