gas shut off
oldiron29
11-06-2007 15:29:22
Had leaky gas shut off on setiment bowl. Farmall Regular original brass with outlet from starter tank. I got new needle from Rice But still leaking. Has anyone had this problem? and can it be fixed? Or do I replace the hole thing. Thanks oldiron29
Janicholson
11-06-2007 16:42:17
 Re: gas shut off in reply to oldiron29, 11-06-2007 15:29:22
I agree with ScottyHOMEy,
If the seat is the issue, it is either cracked (unfixable) or can be dressed with a drill that is sharpened to a point that is "pointier than a regular bit at 118 degrees, but not like a pencil. Probably about 85 degrees. used with finger turning only through a piece of rubber tubing that fits into the threads and keeps the drill centered. Do not take off much at all, it is soft. Use a jewelers loupe to get a close look at the seat before taking action. JimN
oldiron29
11-10-2007 15:42:12
 Re: gas shut off in reply to Janicholson, 11-06-2007 16:42:17
I did notice that the new needle valve had a longer tip than the one that came out of it. More cone shaped. Should I dress the seat or file down the needle? Thanks for your help these are good ideas oldiorn29
Bob Kerr
11-06-2007 21:38:32
I fixed the one on my 10-20 just like Jim said. I also repacked the needle with a neoprene "o"ring instead of the rope packing. It works great and just don"t tighten the nut too tight.To get a good seal on the seat, just remember you need a different angle than the needle and it has to be done very straight. The needle will burnish itself into the seat and seal tight if the angles are right.
ScottyHOMEy
11-06-2007 15:36:12
Could be the seat for the needle. Could also be as simple as repacking it.
