tightening nuts and bolts
Flintlock
10-16-2007 19:24:06
Just split my 300U, new clutch and pressure plate.Removed the IPTO bearing cage, adding new bearings and seals. Also had head work done.And I am installing new front and rear crank seals.And took off the side plate to clean up the tappet area.But I can't find any torque specs for these nuts and bolts except the head nuts. Thanks Mike
Janicholson
10-17-2007 06:53:02
 Re: tightening nuts and bolts in reply to Flintlock, 10-16-2007 19:24:06
Tighten them evenly untill they reach about 5 inch pounds, then just enough more to just begin to squeeze the gasket at the bolt. This is not very tight, but overtightening will destroy the gasket, and cause leaks. I like a very thin film of #2 non hardening permatex, on both sides of this gasket. JimN
