Farmall Super C governer
Ben Milliken
10-09-2007 17:45:52
I need to replace the governer spring on my super c , it looks as if I need to remove the radiator to access the governer.Does anyone have an easier way to change the spring ? Any info will be greatly appreciated !
gene bender
10-09-2007 18:35:52
 Re: Farmall Super C governer in reply to Ben Milliken, 10-09-2007 17:45:52
I rebuild them as the S,SC,A,B,and BN are all the same. Its a close fit but it will come out just by removing the bolts. Now if the input shaft is worn and sloppy it needs a new bushing installed by using a 1/2x5/8 bronze bushing. The housing needs to be machined to 5/8 first. When done with new thrust bearings and spring it will work like new again with throttle response again.
Justin S. - TX
10-09-2007 17:49:58
I just did that myself, i was able to remove it without taking out the radiator, but I did have to remove the shroud bolts and slide it out of the way and the govenor came right off. Hope this helps.
Ben Milliken
10-09-2007 17:53:36
 Re: Farmall Super C governer in reply to Justin S. - TX, 10-09-2007 17:49:58
I hadn't had the chance to take a close look at the shroud , this will definately be easier . Thank you.
