Farmall A Positive ground; Battery Charging
history guy
10-05-2007 19:26:50
To charge a battery with a positive ground do I hook up the positive jumper cable to the positive ground?
Also for a thermosiphon system on a Farmall A can I add antifreeze to the water and still have it flow correctly?
Thanks
Aaron
teddy52food
10-06-2007 06:53:46
 Re: Farmall A Positive ground; Battery Charging in reply to history guy, 10-05-2007 19:26:50
If you took the battery out , how would you hook it up? + to + & - to -
gene bender
10-06-2007 03:33:12
Yes pos to pos when charging. Yes you can add antifreeze to your radiator but be sure to run the tractor to get it warmed up. We always added more when a cold system came because the alcahol would evaporate some and DAD would always say add some more tonite as its going to be colder guess thats why the B still runs and no cracked block.
Pappy
10-05-2007 19:49:21
For your anti-freeze to flow correctly, mix it with water before you pour it into the radiator.
As for charging the battery, always read the battery and connect charger accordingly.
Al L. in Wisc.
10-05-2007 19:39:00
Charging, yup, positive and negative to corresponding terminals. More knowledgeable folk will chime in soon to help w/your other ?.
