856 and loader
H. c. McGee
09-27-2007 18:00:37
Have put a front end loader on the old 856 and it just by-passes oil when I have any weight on the loader and u can not turn the front wheels unless u are moving. Help!!!!! !!!
Owen Aaland
09-28-2007 05:43:32
 Re: 856 and loader in reply to H. c. McGee, 09-27-2007 18:00:37
If all the other front hydraulics work OK (brakes, TA, lube pressure) the most likely cause is a blown oring on the steering relief valve. It is located above a plug that is located on the bottom of the MCV. If you have other problems you may have a weak pump or blown pump to MCV oring.
K.B.-826
09-27-2007 18:38:59
How much weight are we talking here?
H. c. McGee
09-27-2007 20:34:37
 Re: 856 and loader in reply to K.B.-826, 09-27-2007 18:38:59
Starts with only 400 lbs on front end. There is definetly something wrong. hc
