H4 Magneto question
Andy Motteberg
09-13-2007 14:08:19
Hi guys,
I bought a H4 Magneto for my 1943 Farmall H a while back. The grease that goes in the box with the two small gears was old, so I'm going to put in new grease. My question is: How do you time those small gears? On the larger gear, there are two marks on it with a R and a L, and on the small gear, the is a flat spot on one of the teeth. Does the flat gear tooth have to go between the two marks with the R and the L? I hope you can understand this.
Thanks,
Andy Motteberg.
MAGMAN
09-22-2007 12:44:29
 Re: H4 Magneto question in reply to Andy Motteberg, 09-13-2007 14:08:19
IT should line up with R for RH CW trip and L for LH CCW trip. MagMan
teddy52food
09-13-2007 18:09:20
Line up the mark on the small gear with the R for right hand drive on your H. The L is for the gas start diesels.
John M
09-14-2007 03:02:42
 Re: H4 Magneto question in reply to teddy52food, 09-13-2007 18:09:20
Every one I have ever taken apart have had them in between the 2.
teddy52food
09-14-2007 06:29:43
 Re: H4 Magneto question in reply to John M, 09-14-2007 03:02:42
Those marks are close enough that the spark will jump that far from the rotor to the cap. Maybe Magman can reply to this??
John M
09-13-2007 14:24:22
You got it!
Andy Motteberg
09-13-2007 14:27:25
 Re: H4 Magneto question in reply to John M, 09-13-2007 14:24:22
Thanks!
