685 aux valves
karl f
09-12-2007 23:04:42
ex highway mower...this tractor has no hydraulic remote valves. will the pre case ih type bolt up the same as the case ih type (it should be the bosch valves)? trying to broaden the used parts source if it's possible. it doesnt even have the "plate" to attatch valves to. still has the 3pt lift arms/cylinder. you should see the power beyond on this one! right outta the mcv! are there any aftermarket valve systems that would happen to attach in the factory way? t i s c o shows some stackable valve assemblies requiring plates on each end, similar in design to the older ih valves i'm familiar with, but i'm not sure if they share more than the concept. sure do not see many of these in salvage yards!
thanks
karl f
Fromjb2
09-13-2007 09:42:30
 Re: 685 aux valves in reply to karl f, 09-12-2007 23:04:42
Karl, should be same hydraulic remotes as 454 thru 495, 574 thru 3032, 674 thru 4210, 784 thru 4230, 885, 895 and some industrial models.
JimB
