8060 Head vs. 8574 Head
Glenn Jensen
09-05-2007 19:23:52
I was wondering about the main differences between these two cylinder heads? Thanks alot for all your help.
Glenn
georgeky
09-05-2007 21:23:03
 Re: 8060 Head vs. 8574 Head in reply to Glenn Jensen, 09-05-2007 19:23:52
The 8060 is a high compression head.
Charles E. McNelly III
09-06-2007 17:05:30
 Re: 8060 Head vs. 8574 Head in reply to georgeky, 09-05-2007 21:23:03
8060 is the standard gas head for a super M. Can't say it's high compression though. I'm running one with the 5000' alt. pistons and my compression is 115 give or take a point or two. Charles
09-05-2007 19:57:45
The way it was explained to me was there pretty much the same head just one is a newer version. I would assume that the 8574 head would be less prone to cracking since it's the later version.
Good Luck with whichever you choose.
Charles
