W-9 mc cormic's,
kirk in ks,
09-04-2007 12:34:19
I was thinking ,,,if a W-6 would pull a 3-16 little genius, than maybe a W-9 would be even better at alot of thing's?
Ill look at W-9's, and I think Ill get one of those as it would be alot better than my 6 in the long run,
Joe Evans
09-05-2007 05:51:15
 Re: W-9 mc cormic's, in reply to kirk in ks,, 09-04-2007 12:34:19
I have a W-9, and it's a charming chap. It garners attention around Central Ohio as these beasties weren't sold here in any quantity I believe.
Yes, they are brute strong, but YOU have to be brute strong to phish that thing around in tight quarters. I used my 9 one time to do "pull-off" work during one of our Fair's Rough Truck contests. Yes, it was unusual to see something like that, but after that evening I thought I went three rounds with Joe Frazier. What a delight it was to get on our 460 the next day. No comparison in handling and feel. But...ya know, the 9 wasn't made for jockeying hay wagons around. Hooking it to a combine somewhere in Kansas and not turning around until two miles have ticked off is their game. And THAT'S part of its charm, too.
55 50
09-05-2007 08:23:12
 Re: W-9 mc cormic's, in reply to Joe Evans, 09-05-2007 05:51:15
Or how about working summerfallow in North Dakota pulling a 13 or 15 ft chisel plow on 60 or 80 acres, or a 20 ft press drill (two 10s hooked side-by-side) in spring seeding. They were quite common in their day anywhere up and down the central Great Plains.
Joe Evans
09-05-2007 11:22:35
 Re: W-9 mc cormic's, in reply to 55 50, 09-05-2007 08:23:12
Yep, pretty common from out your way. This is row crop country here.
I have not been able to really work my 9 doing hard pull work. All the plows around my area worth hanging behind it are hydraulic lift, and my W-9 was not equipped thus.
Speaking of wheat or wheat land, my brother is fond of looking at the fronts of tractors to see if they are from out west. He says wheat stubble will play heck on metal if enough of it gets rubbed up against an axle or something.
We've got an F-20. I haven't really looked, but he tells me there's a bolt head I guess under the lower bolster or pedestal that's danged near worn away. He says a lot of wheat miles did that.
chuck46
09-04-2007 20:09:52
Hi, I bought my WD9 in 68, put about 10,000 hrs on it. Have used it for a wide variety of tillage, pto, and many other jobs on a dairy grain farm. It pulls a 5-14 model 70 plow or a 15 1/2 ft 45 vibra shank well. I have never understood the HP ratings on the 9's, had mine on a dyno only once it had 72hp at 540. The only way it has been suped up is it has the 4.5 inch pistons. I think they had bigger horses back then. Good luck, Chuck
glennster
09-04-2007 13:08:01
my w-9 will pull a 3-18 oliver, or a 4-16 with out a problem. we had a 4-16 i-h plow, but went to the oliver, the oliver plow could handle corn stalks a lot better without plugging up. oliver had more distance between the top of the moldboard and the plow frame.
