high pressure in hydrolic system
Hank Doodeman
09-04-2007 06:59:58
I have a 1953 Super C Farmall IH, it is building high pressure in the hydrolic system, the fluid seeps out of the of the control piston(loosing fluid), the hydrolics themselves work fine, the pressure in the hydolic resevior is overwelming! Is there any way I can vent the system to prevent this high pressure? I have replaced the fluids and replaced the filter screen(no changes). Any suggestions will help, thanks, Hank.
Janicholson
09-04-2007 07:46:25
 Re: high pressure in hydrolic system in reply to Hank Doodeman, 09-04-2007 06:59:58
I am not sure (but from the diagrams in caseih.com parts) the plug looks to be part of a closed system. if pressure is building, I would look to an intake side (return line to pump) leaking air into the system. JimN
