screaming Super C
Soundmancc
09-02-2007 18:52:55
When I am in 2nd, 3rd, 4th, or reverse the transmission starts to make a screaming sound if going over an idle. If I stop and start the sound also stops until the tractor gains speed. It has not made the sound in 1st gear. Any suggestions?
gene bender
09-03-2007 01:31:15
 Re: screaming Super C in reply to Soundmancc, 09-02-2007 18:52:55
Could also be the oil slinger gear as they can be noisy.
ShaggyM
09-02-2007 20:50:38
If you change out the oil in the trans put a bottle of Lucas oil treatment in it and it will help some with the noise.
Shaggy
Bob
09-02-2007 19:05:36
Have you checked the oil in the tranny and final drives?
Soundmancc
09-03-2007 18:08:43
 Re: screaming Super C in reply to Bob, 09-02-2007 19:05:36
I have not checked the oil level. This is first time that I drove the C since I brought it home. I will have time to check the level this week. I was just moving some trailers around when it started to scream. Thanks for the reminder.
