Randy Hall
Larry806
09-02-2007 13:09:57
third party image
Hey Randy get yours running yet?
Mine was " lightly stuck " Phil could move it a little each way but it wouldn't turn .
I found the clutch housing full of mice nests . When I got that cleaned out it turned over . It will have to be split and ring gear cleaned & new clutch . That is much better than having to get in the motor .The shaft was broke in the Hy pump . Lucky I have a SMD for parts . The radiator was still full of antifreeze when I took it off .
We took the valve cover off and everything in there looks new . I pulled the oil pan and it looks like a low hour rebuild !
I don't even have a Hy pump or dist. on it . But this morning Phil came over and wanted to pull start it . He pulled me about 10 yards and the fuel system bleed out . He didn't pull it 100 yards and it was running on diesel ! I only let it run a minute or so because of the radiator being off .
I'm happy today !!!
randy hall
09-02-2007 15:47:20
 Re: Randy Hall in reply to Larry806, 09-02-2007 13:09:57
hi larry i just came in from baling hay. the third cutting made as much as the first and second together. i haven't had much time to play with my mtad. something wrong in the ta clutch area it won't pull start it acts like the ta clutch won't engage. i took the starter off to check it out and haven't got all the parts yet. maybe you got the best one of the pair. the boys did get that oliver 88 running that we brought home last saturday bvut the clutch is stuck on it. keep in touch, randy
